ported box.. which one
jjoven1225
NJ
i never made a ported box before, and im experimenting one for a friend.. which one would be better?? using a PVC pipe (exact port diameter + length) or building the port as a box.. like this http://www.subzoneusa.com/zv_series.htm
do you tune the box? or the amp?
also the sub requires 2 ports, and port length is 14.75" and port diameter is 3"
also anyone have a good link "how to build ported box" or tuning them or whatever
i've built sealed boxes before just never port and would like to learn, thanks for help
You tune the box to the freq. you want.
Round ports are good if you have the room and the manufacture gives you the diameter and length. Slot ports are good if you have a small box and need so much port area that a round port would be too long or you know what the port area of the box should be and the manufacture doesn't give you the demensions. It's just easier to figure w/o knowing the length and diameter, just the area.
Since you have the length and diameter, I would go w/ the round ones...provided your box can handle the length. ((That's what I told her.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif )) Anyway, check out this and ignore the formula. It may help.http://jlaudio.com/tutorials/ports/index.html
i really dont want to go with the round port, cuz i think slot port looks better.. also since i have the length and the diameter, should i just match the length or of port, with the duck (slot) and same thing with the diameter, just get the area of the rectangle, i figure that's the same thing.. someone help..
that formula was way too confusing..
Originally posted by dbirkes so how would you recommend i build it?
man, are you lucky you got jmac to calculate the box for ya...
jmac, just so you know, my box is solid man, your specs... a little too mcuh though, the sub blew its own gasket off, had to get new surrounds...but now it's fine...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks for everything
Originally posted by jjoven1225 i really dont want to go with the round port, cuz i think slot port looks better.. also since i have the length and the diameter, should i just match the length or of port, with the duck (slot) and same thing with the diameter, just get the area of the rectangle, i figure that's the same thing.. someone help..
To find out the size of a slot port using round port numbers....
you said you needed two ports being 3" X 14.75". This gives you a total port area of 277.89" (3 X 3.14 X 14.75 X 2 = 277.89) This is the area your slot port needs be. Take the opening of the slot L x W (let's just say 3" x 9" to get an opening of 27sq.") What X 27 would give you 277.89??...10.29". That is how long the port wound have to be.
jjoven1225
jjoven1225
NJ
Trixter
vegang
vegang
