Ported Box Bracing Q's...
Boosted92HB
I was wondering which of the two types of braces would be better for a ported box... Would the first one create too much turbulence and make for weird port noise or "whooshing" even w/ nicely rounded edges? Or should I just do regular 45's. I know that the triangles would be fine, but I believe that the X brace would be stronger. Just looking to get a bit more info before i begin to cut wood.
^^^My professional paint skrillz...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
you can do your x-brace but for ease of cutting it you can do a plus sign instead of an x...if that makes sense. Or wooden dowels connecting the front and back, or corner bracing it with 45's.
The main thing that Im worried about is the fact that it would make for turbulence inside the box from the air rushing through spaces... Will that be a problem, or no?
try the brace in pink it will hold the walls very sturdy and wont cause any problems with the flow of air. just keep them at the right distance away from the port to avoid any restriction of air or cause any noise.
Boosted92HB
Boosted92HB
Albany, GA
tRiGgEr
Mike Mccabe
