Port walls?
Well it's a slot port first off. It has the initial port wall running straight back, makes a 90 and this is the second port wall. I am asking can it make another 90 and have a third port wall? I'll try to load up my drawing real fast..
This is the prelim drawing. And what factors of the box size controlls port width?
Well I want to tune it to around 34 and as it is with two walls it is at 38. I'm not gonna compete so that isn't too big of an issue for gaining every db. Any ideas on what will help? The net space is about 2.09 cu ft with 30 in of port at 1.5 in width.
It looks like you have separate chambers for two subs? Is it 2 cubes total or per sub? 1.5" wide of a port is kind of skinny too. The port is like 12" tall, that only yields 18 sq. in of port area for 2 cubic feet, (9 per cube, rule of thumb is 12-16 sq in of port area per cube)
Its gonna be two seperate chambers for two subs. The port is 30 in long and the box is 19 high (17.5 internals). By calculating area (LxW), shouldn't it be 30x1.5 yielding 45 sq in of port. And each chamber is 2.09 cu ft. Is my math off on the port area by that much?
Yeah, you don't get port area by multiplying it by the actual length of the port's path. It's cross-sectional area. How tall the port is by how wide is port area. The bigger the port area is, the LONGER it actually has to be to achieve the same tuning. But, you can't have it too small in port area or it will be like breathing through a straw and the air velocity coming out of the port will be excessive and you will get turbulence and port noise.
1.5" wide X 17.5" tall = 26.25 sq in of port area. 26.25 sq in divided by 2 cubes = 13 sq in per cubic foot of net volume which is actually ok.
So what would you suggest to get a lower tuning? I believe 38 is too high? Am I correct in thinking this? My goal was about 34 hz. This is a daily driver that I would just like to hit the lows.. I am not aiming for any numbers or competing in any way.
Caleb9107
Caleb9107
Somewhere, Nowhere
dappa5
vegang
vegang
