Port Tuning Help - 30 Hz
Decipha
www.EFI Dyno Tuning.com
I'm building a bandpass box, can some one please tell me how to get the ported section tuned to 30 Hz. The INTERNAL box volume (of the ported area) is NET - NET - NET - NET - NET - NET - 1.8037008102 cu ft. The OUTTER perimeter of the ported section measures W30 x H16 x D18, im using 1.25" MDF board. I would like to have two 4" inch in diameter ports if possible. TIA
BTW, the bandpass box is for 2 subs, i figured i can get the ports length and just do the same thing on the other side for the other sub, but i want 2 ports on each sub, 4 ports total.
1.25" Mdf? ****. I wouldn't recommend doing a bandpass box, it's complicated and probaly not worth it.
However, i'll see if I can help. ^ need more details, how many chambers does the box have, what drivers are you using, what shape and size ports are you using? and what is the design you're doing, got any drawlings or something?
Take it easy, i like bandpass's, and really appreciate the help.
The box has 3 chambers, 1 sealed with the subs firing in a common chamber, and 2 soon to be ported chambers. I got the crappy Rockford Fosgate P112S4 subs. I don't have ports yet but i was planning on making two 4" in diameter ports for each sub but i need to know how long i have to make them. No drawings, just a simple square design, if it helps i can post the measurements.
Nope, this is not a forth order bandpass, the rear of the subs will be ported, the front will remain sealed.
okay, I got a better picture, and yeah what are the specs? I'll see if I can plug them into bbp6
__________________________________
|----------_|------------|_------------|
|-------_ /T|------------|T\_----------|
|------[_---|------------|---_]--------|
|--|--|---\_|------------|_/-----|--|--|
|__|--|_____|__________|______|--|__|
I'm assuming the common chamber is the sealed chamber.
My box doesn't look anything like that, the two subs don't face each other but instead are mounted side by side, the complete box measurements are:
30W x 16H x 25D
i have a center board dividing the sealed section and the ported section, and another divider dividing the two subs so they get their own box.
I would imagine you should just go with a more coventional design.
I tried to calculate it, but according to you it's more like two bandpass boxes in one. Just sharing some of the same pieces but all there is 4 chambers 2 for each woofer.
Why do you need 2 ports per speaker? You could make one for each that way it will be easier to tune and you won't end up with too small of ports...
Could you atleast put up a drawling?
i'll make it simple, its just a ported box, not a bandpass, the ported section has NET - 1.8037008102 cu ft. internal volume. The outside measurement of the box is 15W x 16H x 18D. I can deal with 1 port but i would really rather 2 for looks since this will be a fancy install, the port(s) will be made with a 4" in diameter round plastic tube. Can you tell me how long i have to make the tube to tune the box to 28-30 Hz. Thanks.
i'm going to fiberglass the front panel and mirror around the subs with 2 blue neon tubes and a fold down panel for the amp, that illuminates blue when closed. I'll post pics when im done (hopefully soon)
Decipha
Decipha
New Orleans, LA
JimJ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
