Port Size Help & port noise???
momuzykent
Xclusive
Ok I'm deisigning an enclsoure for a friend. It will be one massive audio RW10 (400wrms) running on a 500 watt amp. I have come up with box plans from subwoofertools.com and reaudio.com and want to see which one is correct.
http://reaudio.com/speaker_box/LPort_Box_Calc.html
sub ask for 1.0 cu ft for a 10 and with a displacement of 0.05. box size is 1.147-.05=1.09cu ft and tuned to 36.58HZ. On reaudio i have a 1.25 port width (12in height) and come up with sq port area of 15.
http://subwoofertools.com/forum/ported-box.asp?Ew=19.25&Eh=13.5&Dia=4&Xmax=15.5&Vd=.05&NumW=1&Vb=1.097&Fb=36.58&Qts=&Vas=&Fs=&CE=1.5
on subwoofertools.com it gives me a port width of 2 inches (height 12") and 24 sq inches or port area.
I'm confused now because which do I go with now? Oh, one more thing, manf spec sheets for a ported box say 3" x 8" round port. Does this mean subwoofertools is taking in account the Xmax of speaker and reaudio.com is a general drawing for any subs.?
Kinda confused so if anyone can help i would greatly appreciate to see which design would be best? Also, I do have winISD. Can someone explain with the numbers I gave how do i determine if I will have port noise
thanks,
15 sq in of port is sufficient for a 1 cube box. 24 sq in is overkill...
And the mfg is suggesting a 3" round port, 8" long, not a 3" x 8" port, and a 3" round port only has ~7 sq in of area....
momuzykent
Xclusive
momuzykent
Cashville Tenn-a-key
IonSQL
Mike Mccabe
