Port placement?
  • 4
bowtiefan
East TN
How important is it to have the ports on the same panel as the subs?Is it a must or can I put them where I want them?This will be my first attempt at building a custom ported box so any help will be greatly appreciated....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You should be fine, as long as you don't put them on the bottom...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
there was a book (loudspeaker cookbook?) that said that a port can be placed on any side of the enclosure... but multiple ports should be placed on the same plane
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
985
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
675
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
845
819
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
bowtiefan
bowtiefan
East TN
cifer721
    May 12, 2024
Brendon Jenness
    May 11, 2024
