Port Noise
You can avoid alot of it by getting an enclosure with tapered or slotted ports.
Yes, but you still need to have a sufficiently sized port area/outlet to avoid port noise. The bigger the driver the larger the port opening you need. I believe that the X-max also factors into it too since a farther movement move more air.
BEAVER.989
BEAVER.989
Michigan
ItalynStylion
