port location on box...
Etac
Angry Bunny Killer
im building a box and should be finishing it up tomorrow.. so i just wanna if its true you wanna try to keep the port 3-4 inches from the side of the box... and how much of a difference this would really make?
i didnt put that into consideration and planned on using two 4 inch ports tunred to 32hz (5cubic feet) and i wouldnt be able to get that distance unless i switch to 3 inch ports... but wasnt sure if that would be big enough?
well like i said i can fit the 4 inches... and i think im lose like .25ft^3 cause i gotta shave a little off... but like i said with the 4 inch ports, they would be only like 1.5 inches from the wall.. and im not sure how bad that would really be?
no , im actually just using a really thick peice of pvc pipe, this box is only kinda temporary till spring when its warmer out and will spend more time on it
well the only way thats happening is if i switch to three inch ports or if i point the ports in another direction.. but its a trunk setup and wanted to keep them aiming together
like i said its only till spring maybe ill just go with it for now and see how it goes
but if you ahd to choose between less of a gap or less port space, what do you think is hould go with? or i could fit three three with about 2.5 inches between them
well 1.5 away from the wall w/ a 4 inch port is a bit too close even with a flared port. is there anyway to turn the port inside the box, if you have an elbow that is? whats the setup? same as in your sig?
yeah for now.. i didnt think about elbowing em... that could be done
and just to make sure you ppl know (you probaly do) im not talking about depth being the problem but the side wall...not the back wall
oh, then your good. if the ports are flared, you got nothing to worry about. but even if there is some port noise its in a trunk and it really wont bother ya. got some pics of the box for kicks?
Etac
Angry Bunny Killer
Etac
Jersey
cshaw
michigan born
    May 14, 2026
michigan born
    May 14, 2026
