port length and diameter is based on??
ace_800
Having the guy build my enclosure and he wants to know the port length and port Diameter. I normally just use the calculator on 12volt, but it is based on the size of the enclosure correct? Each sub is going in a .6 ^3 enclosure, so i really can't do 20" straight length port so do i need to wrap the port like a tline to get the 20"?
Its like .72 before roughly.
I can't use 3" aeros. Figure its ~8" high and ~14.5" length and width. Each sub in a separate port on the side with the amp in the middle. Dude is taking about using space under the amp for port length. I don't want to run sealed.
Then you'd better just go with 1 sub. You simply don't have the volume to go ported (with sufficient volume, port area, and tuning) and run 2 subs.
Unless you go very low on port area so your port length is really short it's not going to sound good. If you are too little port area it's more like having a leaky sealed box than anything.
ace_800
ace_800
Okinawa, Japan
ace_800
