port formula
heres the response i got. someone help me interpert.
The speed of sound in air @ 18 degrees centigrade is 1.347*10^4 inches per second that value squared is 1.815*10^8 that squared value divided by 4*pi is 1.45*10^7. The particular equation he is referring to assumes that the port diameter is in inches. The equation you may be using could assume the port diameter is in some other type of unit.
there's two equations I've found:
Lv= [(1.463*10^7*R^2) / (Fb^2 x Vb)] - 1.463*R
and
Lv = Av*1.84*10^8/[Vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av)
so your 1.84 is not in the same context as the 1.463 and shouldn't be considered "right" over a different system of equations.
jellyfish420
i design boxes .......
jellyfish420
STL ill side
sumone
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
