Port Diameters?
  • 2
ShaunMac
Thank You Come Again!
581
GEORGIA
Does it matter what size port(4" or 6") you use as
long as the volume of the ports are the same?
Was going to use a 19" long 4" diameter port.
But I dont have enough room. "depth"
Could I use a 8.45" long 6" diameter port instead?
Thanks
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
742
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
921
897
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
ShaunMac
ShaunMac
GEORGIA
ShaunMac
    May 23, 2024
    May 22, 2024
