popping sound from subs
pico
i have a 75 coupe deville with 2 15" subs connected to a pyramid amp. everything worked fine until a few days ago i was driving home and my subs cut off. i turned off my deck and turned it back on and the subs were popping. the system was working for a few months with no problems and it happened out of nowhere. i checked all the connections and everything is good. does anyone have any ideas on what i can do to fix this?
Amp is flucked!!!
You are trying to get way too much out of the pyramid amp. You are likely expecting it to make the wattage it claims and it isn't, so you turned up the gains and the amp is sending clipped signals to the subs.
Bad Amp...
Shawn...
pico
pico
Modesto, CA
infinity1412
