popping fuses
873stang
i have two amps one for the highs and one for the subs, the one for the highs are is fine, but when i connect the remote wire to the other amp for the subs it pops the fuse for the radio (stock radio fuse), what can cause this?
thx for the halp
lol yea, i checked to make sure its not grounded which its not and i even replaced the wire, it still blows the fuse, do you think i have to run two seprate remote wires? or is it possiable the amp is bad?
where you running the second rem from? Did you try running it from amp 1 to amp 2? If so, that stock HU may need a relay on the rem. Or it could be something totally diffrent. Does the stock HU have rcas? or are you using a lOC? Or somthing like JL cleensweep? But check the rem for shorts .
well i have had it setup as the rem wire from the acc wire to amp 1 and from amp 1 to amp 2. it worked for awhile i don't see why all of a sudden it would start popping fuses
i feel stupid lol duh! lol but ok now if i did that wouldn't i be testing the fues on the amp itself? cause the fuse that blows is the factory radio fuse
873stang
873stang
riverside
Lakota
