5 Two-Channel Amps to choose from...
Jazz
1. Exile X300.2 $199 CAD 300W Bridged at 4 ohm(seems like alot)
2. MTX TC 2002 $183 CAD 200W Bridged at 4 ohm
3. JBL GTO 75.2II $183 CAD 97W Bridged at 4 ohm
4. Phoenix Gold Octane R252 $139 CAD 150W Bridged at 4ohm
5. Pioneer GM 3300TT $112 CAD 150W Bridged at 4 ohm
Which of these seems to be the best deal?
They will be powering an 8" single coil 4 ohm sub of 150- 200 Watt.
Thanks
Jazz
id go with a memphis Mclass over all of those. its a tad bit more expensive, but worth every penny. itll do circles around the others
thanks for the suggestion.
but out of the 5 that i listed, if you HAD to choose one, which would it be?
thanks
Jazz
the JBL
it's not 97 bridged at 4. It's 97x2 at 4, 290 bridged. It's more power than you need, but it's a good quality amp, and you can keep your sub safe by setting the gain accurately. If you decide at some point to change things up the JBL would make a good component amp too.
thanks for the replies.
I will most likely go for the JBL that makes 290 Watt bridged at 4 ohm.
What difference will there be if i get a Dual voice coil versus a Single voice coil and 2 ohm versus 4 ohm with this particular AMP?
I've been looking at the JBL amps. they look **** sexy.
If you run it bridged, you'll need an SVC 4ohm or DVC 2ohm.
is one "better" than the other? ...specifically for the JBL amp that i will buy.
thanks
Jazz
Jazz
Jazz
Montreal
shiipseki
