POLL: (2)18's vs (4)15's vs (8)10's
Which substage setup?
  • (2) 18's, RE MT's, Fi BTL's, HDC3's, etc
    Votes: 13 17.6%
  • (4) 15's, Type-R's, Fi SSDs, RE SX's, etc
    Votes: 40 54.1%
  • (8) 10" L5's or underpowered L7's
    Votes: 21 28.4%
  • Total voters
    74
When you look at cone area, you're doing it all wrong.
You need to look at the Sd of the speaker //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
I would say cone displace would be what to look for imho //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So... radiating cone area wise:
2 18s = 2420 cm^2
4 15s = 3240 cm^2
8 L710s = 3512 cm^2
To give an idea of linear displacement (using the manufacturer's xmax spec)
2 18" BTLs = 6776 cm^3 (28mm xmax with HiXm coils)
4 15" SSDs = 6804 cm^3 (21mm xmax)
8 10" L7s = 4916.8 cm^3 (14mm xmax)
Keep in mind, xmax is one way linear... but you get the idea. And it doesn't necessarily mean one will be louder than the other... a multitude of other factors are also important. It just gives an idea of displacement.
nG
i like the 10 idea...just to show people what they can do and bc it would fool alot of people, that and it would look badass
its really a tough call
now for me, its pretty much out of the 15's and 10's. the 15's have more displacement overall i guess, but the 15's would be firing practically right into each other (looking at the depth of the subs, the sub walls would be at no less than 60 degree angles) which would cause some cancellation.
i like the looks of the 10's better, but its a tough call between all of the setup variables on which will perform better
The tens would be expensive. but would offer maybe teh most longevity just because there are more coils to veny power/heat to.
The 4 15's would be my bet though.
PS plust you could say "four fifteens didnt see no fires, then I heard boom from the amplifiers..."
true, L5's wouldnt run me too much more. the difference between 4 type-rs and 10 L5's is like $150
oh, and i could care less about the quote.
Supergumby5000
Project: F350 begins...
Supergumby5000
Pullman, WA
Supergumby5000
