Sold Polk Audio PA1100.5 5-channel amp
Buickgs231
mi
New took it out of package to take pics. $395 shipped.
Polk Audio built their reputation by making some of the best speakers in the world. Now, they've extended their engineering expertise to their PA Series car amplifiers. These amps offer outstanding sound quality, high power, and a distinctive, stylish look.
The PA1100.5 5-channel amp delivers 80 watts RMS each to four speakers, plus up to 600 watts RMS to a subwoofer — an all-in-one solution for powering your entire system. You'll find the variable high- and low-pass filters useful for tuning your system for maximum efficiency and sound quality, while the bass boosts on all 5 channels add an incredible amount of low-end punch when you need it.
The monoblock amp section of the PA1100.5 handles loads down to 1 ohm, giving you more flexibility in powering your subwoofer setup. The sub section also includes its own separate gain control, variable low-pass filter, selectable bass boost, and subsonic filter for ultimate low-frequency control.
An optional wired remote control lets you adjust your amp volume from the driver's seat. If you're into the show, a connector provides power for an optional external LED light array and fan, so your amp will run and look cool.
Description:
Polk Audio PA 11005 5-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 80 watts x 4 chan. + 280 watts x 1 chan. (@ 4 ohm)
2 ohms: 125 watts x 4 chan. + 600 watts x 1 chan. (@ 1 ohm)
Bridged, 4 ohms: 250 watts x 2 chan. + 600 watts x 1 chan. (@ 1 ohm)
Max power output: 200 watts x 4 chan. + 1200 watts x 1 chan. (@ 1 ohm)
PWM (Pulse Width Modulated) MOSFET power supply
Wired remote volume level control included
LED power and protection indicators
Selectable bass boost (0, +8 dB at 40 Hz)
Double-layer fiberglass epoxy printed circuit boards
5/4/3 channel operation
Subwoofer channel is externally bridgeable with a PA600.1 for even more power! Bridged power is 1200 watts (2 ohm) RMS and 2400 watts Max power!
Connection for optional LED light bar or optional amplifier cooling
RCA preamp outputs
Power/ground-reversal, thermal, short, current, overdraw, and low impedance protection circuitry
Cast aluminum textured end caps
Switchable 180° phase inversion
Variable input sensitivity optimizes match with different signal sources
Unity gain pass-through RCA jacks
Mounting hardware with rubber isolation grommets and extra fuses included.
Effective Damping Factor: >150
Anodized extruded brushed-aluminum cover for maximum heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (50-500 Hz, 12 dB/octave)
Subsonic Filter (24 dB at variable frequencies)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 26-5/16"L x 10-5/16"W x 2-9/16"H
1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
5/6-Channel Car Amplifier
Customer Support | Terms & Conditions
This retails for $899 , Iam sure someone needs a nice 5 ch amp to run everything.
Buickgs231
Buickgs231
mi
Deeper_shades
