Polk Audio MM840 DVC
i see u have the 10s well i wont abuse them im getting in my 30's now and want quality not quantity and im truck driver gone 95% of the year so they wont get used much but the xmax is rated high and the vids of the 10's look retarted i believe they will hit plenty hard enough with one 8 ported!!
Skar VVX 8 or DC LVL 2 but those are a little over $100. PM mylows10 for a price quote on the DC, he is a DC rep.
skar link: SSA Store - SKAR Audio VVX Sub woofer note the low inductance, this is important for transient response, or the ability to sound musical and not boomy.
The Infinity Reference series also comes in an 8 and sells for under $100. It has even less inductance than the Skar 8. The only downside is that it comes in svc 4 ohm only. Here's a link to it, the pdf downloads for the manuals arent working, but I have a pdf for the 8 on my pc, I'll see if I can dig it up. http://www.infinitysystems.com/car/products/product_detail.aspx?prod=REF860W&cat=SUB&ser=REF&Language=ENG&Country=US&Region=USA
copied and pasted from my pdf:
SPECIFICATIONS
DIAMETER: 8" (200MM)
SENSITIVITY (2.83V @ 1M): 91dB
POWER HANDLING: 250WR M S (1000WPEAK )
FREQUENCY RESPONSE: 30HZ ~ 400HZ
NOMINAL IMPEDANCE: 4 OHMS
VOICE COIL DIAMETER: 2.0" (51.0MM)
THIELE-SMALL PARAMETERS
VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.30
VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 2.31
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 33.17
SD (M2) . . . . . . . 214.00
MOTOR FORCE FACTOR: BL ™ . . . . . . . . 12.56
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 0.54
VAS (LITERS) . . . . . 15.23
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 232.70
MOVING MASS, AIR LOAD: M MS(GRAMS). . . . 124.20
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 122.40
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 29.60
MECHANICAL Q: QMS . . . . . . . . . . . 6.10
ELECTRICAL Q: QES . . . . . . . . . . . 0.483
TOTAL Q: QTS . . . . . . . . . . . . 0.45
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . .0.315
HAG (MM) . . . . . . . . 8.00
VOICE COIL HEIGHT: HVC (IN) .. . . . . . . . . 1.34
HVC (MM) . . . . . . . . . . . 34
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . 0.513
XMAX (MM) . . . . . . 13.00
Yea, it did pretty good for an 8. Its the only 8 that I've heard in person. SQ was great and it got fairly low due to the low fs and 13mm of xmax. It didnt get that loud to me, probably due to the sealed box and I'm used to hearing bigger speakers so I think I had high expectations. And the amp was a 250w rms so it wasn't getting much power after box rise. I recommended that a friend get one, after they heard my Ref 1262w's and wanted something better than stock. If I would have known about ported boxes then like I do now, I would have built a box for it.
can't go wrong for $50 though. You could even get 2 and not go much over $100. In WinISD with .7cu/ft tuned to 30hz it yeilds an f3 in the mid 20s.
http://www.google.com/products/catalog?q=infinity+ref+860w&um=1&ie=UTF-8&tbm=shop&cid=2856062076805969443&sa=X&ei=P_wMT_DvF6W20QHt1sySDw&ved=0CDMQ8wIwAQ#scoring=tp
yea the price and the freq. range is what really draws me to get these there r so many choices out there though, but i think im gonna go with the Infinity!
timsm80
timsm80
Lexington,Tn
timsm80
