Plexiglass Question????
I assume carbonated means there is a filler substance, possibly air in it, so that not as much acrylic is needed, and possibly not as strong.
I don't know, but that is my best guess.
I would find out what the different actual materials are in the poly-carb.
Maybe carbonated is more expensive because it's not like carbonation like added to a soda but as in carbon the element added under heat and pressure like how you make a diamond. /shrug..
check out http://www.estreetplastics.com for plexi and Lexan.
Plexiglass (acrylic) is a versatile material that has great impact strength yet is light weight with exceptional optical quality. Plexiglass (acrylic) can be used for a number of applications such as signage, glazing, displays, picture framing, aquarium tanks, and much more. Plexiglass (acrylic) is easy to work with. It can be sawed, drilled, routed, glued, painted, decorated, silkscreened, and formed.
Our plexiglass sheet inventory includes a number of stock sizes that are usually ready to ship within 1 to 3 business days.
Acrylic refers to a synthetic plastic material. Plexiglass, plexi-glass, lucite, acrylite or acrylic glass are often used to describe acrylic. There are several manufacturers of acrylic sheets. Some of the brand names of these manufacturers are Plexiglas, Chemcast, Acrylite, Lucite. Plexiglas® is a registered trademark of Arkema, Inc. The actual brand we ship out will depend on current stock.
Polycarbonate, aka lexan, is a tough and durable plastic material which is hundreds of times stronger than glass and many times stronger than acrylic. Polycarbonate will meet those demanding applications where glass and acrylic fall short.
Hope that helps, I'd suggest going with 3/4" Lexan although 3/4" plexi would work also.
stl_style
Registered User
stl_style
Around the corner
stl_style
