please tell me im not screwed here....
I liked the idea of sticking some tape to it. maybe some double sided 3M, wait for it to stick, try to pull it out, rubbing alcohol to un-stick it.
i feel like im gonna need some super duper special tape for that... i shall give it a shot though
i can send ya 1 out, pm me.
cut the old 1 off. a dust caps biggest function is for cooling esp on a sub with a solid pole. it dose stiffen the cone and keep particals out of the gap...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
498
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
608
pbnj22
pbnj22
Duluth MN
SPLaudio
    Jun 1, 2024
    May 31, 2024
