Please- need HELP ASAP
98gtx
NY
Hooking up a LOC on a 2003 Bose Tahoe right now.
My right rear door has yellow and brown wires- does anyone know which is +/-??? I want to tap these for the LOC.
The speaker does not have it labeled.
THANKS!!!
You need the rest?
12v = orange
ground=black/white
factory amp turn on=pink
antenna=dk. green
LF speaker=tan+ grey-
RF=lt green+ green-
LR=brown+ yellow-
RR=blue+ Lt. blue-
whered you get that info? I've been needing to know the switched 12v+ for my 2001 grand am for over a year now... I've tried using dmm, but none of the wires behind my HU have voltage in them, maybe it's broken or something? For over a year i've had no memory in my HU, i've got the switched wire on my parking lights, so when i want to turn on the radio in daylight, i have my lights on as well and it's hella annoying.
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
985
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
986
685
  • Locked
Hello new to forum but in desperate need of help need 2 of the waffle 8 in grills from PPS4-8 or 8" like in pic please help thanks
98gtx
98gtx
NY
dantheman8328
Decebal
    Jun 10, 2024
