Please help!
Jsc421
I ordered a Sundown Audio SA12 D2 and I have a RF 500w amp at 2 ohm. So I have a 2 ohm sub and a 2 ohm amp. Can I wore the 2 ohm sub to the 2 ohm amp? I know you can wire 2 ohm to 1 ohm or 4 ohm but I want to upgrade to 1 ohm amp in future for this sub but don't have the money right now. Thanks.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
953
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Jsc421
Jsc421
Omaha, NE
hegar817
    May 16, 2024
    May 16, 2024
