Please help.
Heres teh spec of the amp
# FULL MOSFET POWER SUPPLY
# SYNCHRONIZED LIGHTNING PULSE DISH
# PWM CIRCUITRY
# FULLY SELECTABLE CROSSOVER
# (HIGH / FULL / LOW)
# 3-WAY PROTECTION CIRCUIT
# & TRI-MODE CAPABLE
# 2? STABLE STEREO
# VARIABLE LOW PASS: 40 HZ–250 HZ
# VARIABLE HIGH PASS: 40 HZ–250 HZ
# 10 DB BASS BOOST @ 40 HZ
# FREQ RESP: 10 HZ–30 HZ
# S / N RATIO: 98 DB
# THD: 0.02%
# SYSTEM DISTRESS INDICATOR
# 4-GAUGE POWER & GROUND CONNECTION
# LINE OUTPUT
# DIAMOND-CUT HEAT SINK
# PLATINUM-PLATED RCA CONNECTORS
# 2-CHANNEL
# 620W @ 4? MONO
# PWM CIRCUITRY
# 2? STABLE STEREO
# THD: 0.02%
# LINE OUTPUT
# 2-CHANNEL
# 620W @ 4? MONO
the only way you could wire a dvc 4ohm sub to that amp would be to use each channel @4ohm and run A coil per channel
# RMS Power (4 ohms) 150 watts x 2 channels
# RMS Power (2 ohms) 180 watts x 2 channels
# RMS Power (1 ohm) Not Stable
# Bridged RMS Power 360 watts x 1 channel
# Total RMS Power 360 watts
# Peak Power Output 620 watts
# Minimum Impedance Unbridged 2 ohms
# Minimum Impedance Bridged 4 ohms
Livin' Loud
USA
Livin' Loud
