Please help with crossover points
2Gemini
IL
I just got a set of PG 6.5 components installed and powered by a four channel amp. Tweets are on the front channel and Mids are on the rear. As of right now I am not using the provided external crossover.
My headunit has built in "active" crossover. What should I set my crossovers to on my tweets and mids so I don't damage them?
HU Crossover HPF are: 40, 60, 80, 100, 120, 150, 180, and 220Hz
Once again, what should I set my mids and tweets to?
Or should I just use the external crossovers?
Thank you VERY much.
Why not?
My headunit has built in "active" crossover. What should I set my crossovers to on my tweets and mids so I don't damage them?HU Crossover HPF are: 40, 60, 80, 100, 120, 150, 180, and 220Hz
The HPF in your deck is meant to roll off the fronts relative to the sub. You can't use it to x-over the tweeters and the mids.
I you may want to learn a little more about the process before proceeding. Good luck.
2Gemini
2Gemini
IL
2Gemini
michigan born
    May 14, 2026
michigan born
    May 14, 2026
