please help with comps ! crackling sound at mid to high volume
duro78
I recently bought a set of image dynamics cxts or ctx's can't think right now but they sounded great but one day i started hearing a crackling sound at mid to high volume on the left side now both sides. if I keep the volume low I don't hear it and sometimes when I raise the volume I don't hear it but its annoying.I originally thought I blew the right tweeter but hen both sides started and I'm pretty sure its coming from the mid bass also. Ive blown few tweets in my day and when I did they just didn't work anymore. Is it my rca's, amp, amp outputs, speakers or wiring touching somewhere? Please help i don't want to start pulling everything apart rather go to the obvious first
you need to learn how to set up a stereo properly. I have never blew a speaker in 15plus years of doing car audio.
you damaged the tweeters from clipping the amp. amp clipping causes high frequency harmonics. those harmonics put a lot of power into the tweeters, which will destroy them quickly.
your absolutely right I remember foolishly pushing too far
How likely are you to damage the mids at the same time as the tweeters on a component set like this? I've just done the same thing as duro it seems.
Depends. Sometimes it's just blown crossover capacitors on the tweeters.
Only on REALLY cheap x-overs or the ones you find on coaxials, I would just go for -6db attenuation and a negative eq curve starting at around 2.5khz or slightly hgher depending on what your tweeters play down too.
Every capacitor has a voltage rating. Exceed that and it pops. Higher voltage caps are larger and more expensive. Few companies over-design, and the cap can protect the tweeter if properly sized to pop before the tweeter.
Yep, that's what I was referring to those little non polarized electrolytic caps, d@mn things sound like a .22 going off by your leg!
---------- Post added at 03:09 AM ---------- Previous post was at 03:08 AM ----------
I had a smoking tweeter yesterday:) Clipping it snott out of it..still plays, but as stated..Its only money..Replacing soon:santa:
Man that could not have sounded good with enough going to it to roll smoke!
duro78
duro78
new york
keep_hope_alive
