please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I want to know if anyone can tell me how to hook up my two 4 ohm 10" subwoofers to my 2 channel amp? I know that when my amp is bridged the lowest ohms I can put on it is 4 ohms, because the amp will read it as being 2 ohms. My question is should I bridge my amp and wire my subs in series to get 8 Ohms or should I put one 10 per channel at 4 ohms a peice. I just want to know wich way is going to give me the most watts to my subwoofers. PLEASE HELP ME! Thanks for any answers.
it will be about the same depending on the amp. I would probably try and trade the svc subs for some dvc subs if it is possible. Or maybe try and trade your 2 channel amp for a 1 channel amp. If not then just try both ways and see if you can tell a difference, becuase if you cant tell a difference between the two then there is no point to try and wonder which is really better //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
olsoncsb23
olsoncsb23
Martinsburg, WV
phoneman
Doxquzme
    May 13, 2026
