Please help me wiring my comps
xjmadness
The beauty of green
Hey guys i got a ? for yall.
I got a 2 channel MTX amp and MA audio SYC051 components. I have run into a problem trying to figure out how to wire them. There are outputs + inputs on the xover for both the mid and tweeter. So how can i wire the 4 output wires(+- +-) into a channel (+ -)?
thx
thx
the xo goes after the amplifier not before, then you only have one input line that gets amp and sent to the xo to split between the tweet and mid driver.
i know that...this is how my xover looks like...
Mid......................High..................Mid.............................High
Input..................Input...................Output....................Output
so how do i wire it?
There's one for the woofer and one for the tweeter. (Bi-Amp Set-up)
You're using one amp for the components.
Try wiring the woofer and tweeter in parallel on the x-over.
This will drop your ohm load and give you more power
from your MTX amp.
Or check with MA Audio to see what they reccomend.
i don't want any more power from my amp. The RMS ratings match up well @ 4 ohms //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In order to get the 4 ohm load it will depend
on if the MA x-over has any kind of ohm compensation
circuity. This enables you to wire two 4 ohm speakers
together for a 4 ohm load.
If it doesn't have this, you will either wire them up
for a 2 ohm or 8 ohm load. If they are both 4 ohm speakers.
MA may have a way of wiring it up with one input.
Such as using the tweeter +input and the woofer - input
Sorta like bridging.
i was bored one time so i played with a biampable crossover once, to me it doesn't make a difference at all, unless you're running two different amps, one for hi and one for low, but other than that, it doesn't make a difference...
you can just use one output.. i also tried the low output and the high output to see which one would sound better, and they both perform the same, the only difference is, the one that i use with hi input, it gets the sound quicker/faster than the low input..
they're great speaker.. i installed them in my father's car..
so i suggest if you're using just one two channel amp, just use one of the inputs, i prefer the high, but either one doesn't matter,
oh yea just remember the midbass/midrange is DVC... when i was playing with it last time, i thought the speaker was ****ed up, but i look and saw it was DVC so i connect both and now it works.. again if you wire it series or parallel, it doesn't make a difference (i think) well i wired mine in parallel tho..
good luck, just curios how much did you pay for that component, i paid $40 shipped for it, brand new with one year warranty =), that's why i think it's ****ing great speaker..
xjmadness
The beauty of green
xjmadness
ATL
xjmadness
vegang
vegang
