PLease help me pick a HU!
astupidiot
I'm very interested in the Pioneer AVH-X3600BHS, but have an iPhone 5 and have heard/read a LOT of bad stuff about compatibility between those two. If that is true, then I'm looking for something that is double din, DVD, bluetooth, and HD radio. A detachable face would be nice, but not needed. I'd like to do this soon (before my wife spends it all) so please help quickly! Thanks in advance.
If it has a USB port, it works with the iPhone 5. Any issues are caused by a cheap cable that only charges and doesn't sync. Any cable that isn't apple certified (doesn't have the sync chip) will not work. The Amazon brand charger works well, along with the original Apple charger.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
astupidiot
astupidiot
Milwaukee
jnewnam88
