Please help in ine crossover question
  • 4
No mention of capacitors but most entry level components use a simple capacitor as a filter.
He never said if it was high- or low- pass... add that to your google list so you can try to sound smart in your next post. Nothing wrong with learning; a lot wrong with talking about things you don't know.
It is called reading. His first post has this:
The problem is there is just way too much treble unless I use an equalizer
Now with my superpowers of deduction, I deduced there was a what? Say it with me Joe, an inline bass blocker aka capacitor! As we all good DIYers know, OEM tweeters have this built in. So reaching into my utility belt, I pulled out my boomerang of intuition. Swung it around in a wide arc, let it fly to collect tidbits of information that I used to peice this mystery together! And what was the end result.... Solved!
I will be signing autographs at a Jigglehut near you. Drop by and I will give you a free autographed shirt.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Jr1993
Jr1993
Minnesota
    Jun 1, 2024
    May 31, 2024
