Please help if this setup is crap!!
sn03
Master of WannaBe
Just for entry-level purposes, is it good?? I need the time-alignment in a cheap HU, so the Sony. And it must be single-din!! Seen other options, e.g. deh-80prs, but they are either too costly, or don't give enough features, or aren't available at all!!!! Well, it's India man, not USA!
MY SETUP-
  1. HU - MEX-N4150BT
  2. Front - VC 652
  3. Rear - Focal 6x9 coax (don't remember model, shall post later)
  4. Front sub - 2x focal auditor RIP 250S (dual-voice coils)
  5. Rear sub - TS W306R
  6. Speaker amp - XM N1004
  7. Sub amp - GX A3011Si (each sub)
I know many shall object the rear speakers, but I can (and will) keep them off most of the time. They are for just experimental purpose.
All subs shall be in sealed boxes. The 2 in front shall be placed in the footwells, and the rear one shall be firing directly front, (without seats). The front subs shall do most of the work, the rear one is solely for the very lowest of frequencies
MY SETUP-
  1. HU - MEX-N4150BT
  2. Front - VC 652
Try to see if you can get something that has a 24 bit dac, 13 band EQ, network mode and 4 volt pre-outs
like this model JVC KD-X340BTS which costs less than that sony in the US market and is in every way superior.
Rear speakers should be on head unit power. Your amp should be used to run active network mode or bridged for the front components.
sn03
Master of WannaBe
sn03
Guwahati, India
Jeffdachef
