please help!!!!!big question!!!
  • 4
mdd99
if i have an alpine 9813 which will have alot of mode to choose and i will buy and mb quart rsc 213 which have crossover. is the crossover worth anything if the alpine already have crossover. or should i go with coakcial speaker. will it sound good if i hook it up to the alpine receiver with the crossover. my second question is if i hook the rsc 213 to an amp can i hook another speaker to the alpine at the same time so that equal eigth speaker. if i can hook it up that way should i use coakcial speaker or component to hook it up to the head unit.
Please solver this big question for me....thannnnnnnkkkk..
the crossover of the mbquart's set is to separate the frequencies that will be carried by the woofer and the tweets. while the HU crossover is not for this purpose. it separates the frequencies for sub and mid. you can hook up another speaker to the HU when your rsc is hooked up to an amp, but for what? the sound the amp produce will definitely cleaner and louder. the second set run by HU will only ruin your SQ.
Originally posted by zephyr you can hook up another speaker to the HU when your rsc is hooked up to an amp, but for what?
My guess is he only has a two channel amp. You can run a set of speakers off the head unit if you wish. I recommend making the rears the ones off the head unit and the components off the amp.
Originally posted by zephyr the crossover of the mbquart's set is to separate the frequencies that will be carried by the woofer and the tweets. while the HU crossover is not for this purpose. it separates the frequencies for sub and mid. you can hook up another speaker to the HU when your rsc is hooked up to an amp, but for what? the sound the amp produce will definitely cleaner and louder. the second set run by HU will only ruin your SQ.
I agree
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
954
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
mdd99
mdd99
Los Angeles, CA
LBX2G
    May 18, 2024
    May 16, 2024
