Please confirm cutout diameter
adulbrich
Olive oil un-virginer
14,433
123
Ames, Iowa
Anyone else have subs with 6 spoke 18" frames? I'm cutting the holes in the baffle right now, and I need to know what diameter to cut. I've read 16.5", 16.75", and even 17". Subs are going to be inverted.
So how big should I make the holes?
Traditionally all 18" baskets are 16.75" cutout. If you want to be absolutely sure, just get something that's flexible like some scrap speaker wire and measure the circumference then divide it by pi.
343
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
272
967
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
adulbrich
adulbrich
Ames, Iowa
adulbrich
Brendon Jenness
    May 8, 2024
    May 8, 2024
