plans for 4 8'' assassins
goose5741
i need some designs for 4 AA assassins, specs say .6cuft per driver ported at 40hz, but i want it tuned lower, maybe around 32???? whatever whoever makes me some plans thinks will be best. Nothing really matches up in the free plans....need these in the next 2 hours, max outer dimensions of a box would be (HxLxD) 17x40xwhateverit needs to be....not really sure how you would place the woofers to make this work, i can pay up to 10$ for plans, preferably 5 tho lol.....i won't be on to ok anybody to make them cauze i have class, if someone wants to give it a shot and they work i will pay...feel free to tweak the box however you think would be best at for a general sql setup with these drivers as enclosure design is a weak area for me.....
like i said i kno little about boxes, better with the electrical side of things...so whoever knows better than me make the decision and i will pay you haha...i liked my mag at 32hz.......so maybe we will go more around there?
Thx for the advice!
35hz sounds fine to me, if someone decides they want to make these call it out so not more than one person does, like i said i will pay, going to class now be back in 2 hours...
Something like this? PM me if you want to make changes or for dimensions.
You will lose a ton of output with no real gain in low end tuning to 35hz. They play FLAT in the recommended box. The absolute lowest I would go is 38. I've run a pair in .6 per tuned to 40 and they do better on the really low stuff than on the upper bass. I had no problem with anything I played and there was not an issue with them bottoming even though I had about double the rated power going to them with no SSF. They were also quite detailed and able to distinguish the individual notes with complex bass lines. Tune too low and the group delay will go way up and the bass will get really muddy. You can't just arbitrarily say "that's too high." I'm about to go with 4 of them in my next vehicle at the end of the summer and I'm planning on .6 per tuned to 40hz.
goose5741
goose5741
DUBUQUE, IOWA
Mitch86
