Planning a system.
purebullet417
it says that that 800@2 is rms but seeing it only puts out 1600watts max just doesnt do it for me ha.......i will sell you a DD m1a that puts out 1200watts at 1 ohm and is wayy underrated....most people say it does about 1600watts,,.....and thats still rms
how many rms about would it put out @ 2 ohms then? you cant wire a dual 4 ohm sub to 1 ohm so it has to be wired to 2 ohms. im picking it up used off someone thats why im stuck with the dual 4 ohm
Max power doesn't mean a **** thing.
RMS is the ONLY power rating to look at here.
To answer your question, underpowering the sub will not do anything at all. It's exactly the same effect as when you turn the volume down - it puts less power to it. All it'll mean is you get slightly less volume in contrast to the full power - but the difference between 800 and 1000 watts will be minute.
thank you thats what i needed to hear
purebullet417
purebullet417
long island ny
purebullet417
