Planet Audio AC1500.1M Amp going into protection Mode
I have a Planet Audio 1500w monoblockamp on my psi platform 2 12 dual 1 ohm with direct leads and it goes into protection mode if I turn the radio up over 20 and it is really annoying. I want to know if is because of the way I wired it which is I just put the two hot wires on one terminal and same with the ground or if it because of any other reason
Please tell me you didn't buy a $300+ sub and you're using a $60 amp to run it. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
The amp is stable down to 2 ohms. It sounds like you have a dual 1 wired parallel -- that's 1/2 ohm.
Being that it's only 2ohm stable and it's wired at .5 you also lose a lot of efficiency and have bad voltage drop at the amp as well both wiring to low and voltage drop will kill an amp fast. I can almost guarantee you are clipping as well. Once you have figured out how to wire it correctly look up how to properly set a gain.
billyc.d
billyc.d
Chickasha Oklahoma
dbjunior
