pioneer TS-W306C or kicker comp
i dont know this is confusing me...
so those are the 2 same subs? i also found out the dvc and svc are basically same price...
im gonna run 2 (TS-W306C)with an amp to be purchased later... so i should just get the svc subs? theres no better choice considering how loud they get or performance wise?
slaugh what is urs? dvc or svc
(2) Pioneer TS-W306DVCtax: $8.39
shipping: $6.26
total: $134.55
(2) Pioneer TS-W306C
96 shipped
so i guess im gonna go with the single voice coil version if theres no real big difference for me not to
well lets think about this. If the SVC ones are 4 ohms, you will need to spend much more on an amp to power them at 2 ohms rather than 1.
so if i got the svc, there both 4 ohm wire them togetheer would make 2 ohm right? so i would have to get like 800 watt rms at 2 ohms correct?
for the dvc i wire the dvc to 2 ohms, then 2 subs makes 1 ohm , so thats 800 watts at 1 ohm
all this is correct?
yup. It would be cheaper to find an amp that does 800 at 1 ohm as opposed to 2
alot of amps im lookin at cant play at 1 ohm ? or are they not just showing it? im searching thru caraudio.com amps section...
i want to pair the dvc and svc with a equal amp to push them and then just select the cheapest package
If you want cheap, pick up a HiFonics Brutus BX1000D. 1000 RMS at 1 ohm mono. Will be perfect for those subs, and cost you less than $200 brand new shipped.
Boss Riot 1500DRMS Power: 800W x 1 @ 2 Ohms
Our Price: $184.95
http://www.cardomain.com/item/BOSRT1500D
Boss Chaos C1200
RMS Power: 600W x 1 @ 2 Ohms
Our Price: $157.95
http://www.cardomain.com/item/BOSC1200
those are 2 i found for the svc subs, they are kinda pricey =-(
theyre pricey, and wont come close to producing their advertised power. If you dont want to spend much money, try to find a used amplifier that does about 400 watts RMS at 2 ohms. 200 per sub will get them moving pretty well. But personally, I would spend $50 more and get exactly what you need rather than something that will just "work."
http://www.ikesound.com/product-product_id/2426
Twistid
Twistid
in a space out of sound
SSS 18734
