Pioneer TS D690R wiring help! + and -
I know for a fact, I've wired them both ways, as long as you get 'em the same, I couldn't tell a difference.
I do know, that in the electrical trade, the fat prong is always the IC, Neutral, or Negative in this case, so that's what I typically went by
Think I found the answer
How do I tell which is positive and negative on my new speakers?
There are several different methods that manufacturers might use to indicate speaker terminal polarity:
* On most full range speakers, two different size terminals are provided. The larger terminal indicates positive, the smaller terminal is negative.
http://www.crutchfield.com/S-03IxGdAdBLl/tech/kb21.html
volsrock
volsrock
Morristown Tn
volsrock
