Pioneer Time alignment
by time adjustments, im assuming you mean change the time. I do not have the same deck as you but its a Pioneer, and tricky to chance the time. Not sure if it has same buttons as your deck but maybe this will help. Hold down the "source" button until nothing shows, then hit the the audio button (if you get through this and doesnt work, hit the time button). once you hit this the clock numbers should appear, then change it by hitting the arrows. Once you have it set leave it for a second, and then hit source again and it should work.
Measure distance from each individual driver to your ear , while your seated in your listening position first //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeppers...then once you do that you either input the numbers in inches or centimeters depending on model. Eclipse units you have to do a little math, but most pioneers accept inches.
HA
lol, not quite the same thing...........
if it had a "time button", don't you think it would've been obvious?
dishon22
dishon22
atlanta
Chevyaudio
