if your looking at this you should know what it is and how they put out around double what they are rated .......I said 2 days ago I wouldnt sell this amp but I must realize that I cant hold on to stuff if I am not going to use it .....
This amp is in excellent shape and sounds great ...
here are some quick specs
Output Power at 14.4V (20Hz ∼ 20kHz):
4 x 37.5W @ 4 ohms (0.04% THD)
4 x 75W @ 2 ohms (0.4% THD)
2 x 150W @ 4 ohms bridged (0.4% THD)
THD:
Freq. Response: 10Hz ∼ 50kHz
S/N Ratio: 105dBA
Channel Separation: 65dB (1kHz)
Fuse: 3 x 30A
Dimensions: 13.6" x 10.4" x 2.6" (34.5cm x 26.4cm x 6.5cm)
Weight: 15.4 lbs. (7 kg.)
New Retail $625
Note the THD and the S/N ratio...both excellent..........power output for these is widely known to be double or close to it...some of the most underated AND CLEAN power ever put out...
$150 shipped or PM me ....I will get pics today
THD:
S/N Ratio: 105dBA
Fuse: 3 x 30A
New Retail $625
