Pioneer Premier PRS-X720
bigguy2010
SQ
736
MI
Used, but in great shape with end cap and ALL screws.
$150 shipped
Continuous Power (20Hz-20kHz, 0.04% THD)
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 200Wx2
1 ch: (4 Ohm) 400Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 250Wx2
1 ch: (4 Ohm) 750Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion:
Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
Bridgeable 1/2/3 Channel Capability
PWM Regulated MOSFET Power Supply
2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
Balanced Isolator Input Circuit
Oversized Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Full Range)
Hi-Volt Input Level Control (400mV-6.5V)
Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
Variable Bass Boost (40-120Hz, 0 to +18dB)
Subsonic Filter (15Hz, -18dB/Oct.)
bigguy2010
SQ
bigguy2010
MI
bigguy2010
