Pioneer Premier PRS-D800 small class fd amp 2 channel $120
gentlejax
Item(s) for Sale:prs-d800
Item(s) Description/Condition:used but fine..slight scrathces
Price:120 shipped
Legendary Pioneer Quality
The Pioneer PRS Series amplifiers deliver unrivaled sound quality with an ultra compact chassis. This 2-channel amplifier is ideal for running a pair of high quality speakers and components. The PRS D800 produces 125 watts RMS of clean power at 4 ohms. If you have a low powered subwoofer, this amplifier can switch over to Mono channel mode for 300 watts of power. Anti-vibration martial eliminates distortion by increasing internal stability. One thing that sets this amplifier apart is it's absence of frequency filters or bass boost. This is to allow the amplifier to perfectly replicate the signal that is being inputted to the amplifier. This results in the speakers producing the exact signal that are being sent from the source unit. Get the quality you deserve with the Pioneer PRS-D800 today!
General Features:
2-Channel Class FD Car Amplifier
RMS Power Rating:
4 ohms: 125 watts x 2 chan.
2 ohms: 150 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Oxygen-Free Copper Wire Coil for Output
TVC(Total Volume Control) increases signal-to-noise ratio
Pulse Width Modulated MOSFET power supply
Soft start turn-on
2 or Mono channel operation
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heat-sink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
CEA-2006 compliant amplifier
Frequency response: 10-30000 Hz
8 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 10"W x 4-1/8"D x 2"H
gentlejax
gentlejax
Bossier City, La.
gentlejax
