Pioneer PREMIER DEH p860mp
JayRich
Item(s) for Sale: Pioneer Premier DEH-p860mp Headunit
Item(s) Description/Condition: Its is good condition no scratches to the faceplate and I am not aware of the pico fuse issue as I used a ground wire to negative of the RCA's from the first time I installed the unit as a preventative measure. I give it a 8/10 as when the unit is on there appears to be a couple of distorted pixels in the left corner in a vertical line but not visible when you have a screen saver going. Functionally its 10/10 no issues. Just changed to a headunit with Bluetooth and USB port for convenience as most of my music listening is now on my HT system.
Price: $175 Shipped
Shipping and Miscellaneous Item Information: USPS Medium Flat Rate Box included in Price
Specs:
Premier™ CD Receiver with Customizable Multicolor Organic EL Display
Auto Slide Flap Face
MP3/WMA/WAV Playback
Built-in DSP with 13-Band Graphic EQ
Auto-EQ and Auto Time Alignment
Burr-Brown DAC's
BMX Digital Compression
MOSFET50
XM Satellite Radio controls (tuner, antenna, and subscription required and not included with purchase)
Supertuner® IIID™
10-Key Remote
Rotary Volume Control
Detachable Face Security™
Hi-Volt Preouts: 6.5V, 100 ohm
CD-Text Compatible
IP-Bus Expandability:
RCA Outputs: 3 pair (Front, Rear, Sub/Non-Fading) or PRO Mode (High, Mid, Low)
Built in HPF/LPF Crossovers: (50/63/80/100/125/160/200Hz, 0/-6/-12dB/Oct.)
Updatable Screensavers
IP-BUS System Control
XM Radio Ready
iPod Adapter Ready
Multi-CD Control
DVD Control
TV Tuner Control
Auxiliary Input
External Unit Control
JayRich
JayRich
Richmond, VA
JayRich
