Sold Pioneer Premier - Champion Series PRO Sub.
RetroAudioinc
Custom Car Audio Decals
1. Product:
Pioneer TS-W2501 D2
2. Specs:
  • 10" Dual 2 ohm Premier® Champion Series PRO Subwoofer
  • Power Handling:
    Peak: 2500 watts
  • RMS: 800 watts
[*]Impedance: Dual 2 ohm
[*]Air Suspension System for consistently clear, powerful, wide ranging bass response.
[*]110oz Double-Stack Magnet with Double-Stack Top Plate
[*]Wide-Roll 3-Layer Fiber Radial Surround consists of two layers of urethane with a layer of interwoven fiber between them. It's strong, stable, and it reduces distortion. In addition, the wider-than-normal design provides a long, linear excursion for excellent control and heavy-duty durability.
[*]IMPP Cone with Carbon Fiber/Glass Fiber Reinforcement: Pioneer invented the process of injection-molding polypropylene to form a speaker cone. Now, the IMPP is reinforced with carbon and glass fiber, providing speaker cones with extraordinary strength and rigidity — and light weight. This is ideal for powerful, accurate music. And it gives the cones the durability needed for withstanding heat, humidity, and dust.
[*]Cast Aluminum Basket: one-piece aluminum basket assembly holds the motor assembly, cone, and magnet structure securely in place. The benefits of this design: reduced internal stress, superior damping, and increased magnetic efficiency.
[*]Integrated Single-Sided Silver Compression Wire Terminals
[*]Frequency Response: 18-1000 Hz
[*]Sensitivity: 87 dB
3. Description/Condition:
Brand New in the box.
4. Price: :
$100 + actual shipping USPS Parcel post, USPS priority or ups ground
5. Pictures:
This sounds very nice, with tuning under 34hz they do become too bottom end heavy, but that is never a bad thing. Lots of output from 45hz and down. I had 2 12s tuned to 32hz in a 3.2 cu ft. box and was doing over 136dbs at 30 hz, with a hifonics brutus 1208D
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
