Pioneer p80mp wont eject
I have had that problem with every pioneer I have ever had... Even my 6700 is starting to do it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
It ejects part way? If so push down on it with your fingernail as you push eject right before it gets stuck, then it should come out enough for you to grab it.
try to slide the face plate off even though it's closed (u might have to use a small flathead/knife to push the release button in the back). after you get it off, spray wd-40 on the gears, make sure u get the gears in the back that u cant really see. should work fine after that.
its weird...i tried to disconnect the deck and reset it but i when i took out the mounting kit it ejected..now it works again...i think pioneer decks are sensitive to heat and cold...cuz i left the face this time..and thats when it stopped working..ahh well...i guess its fine for now..
i have the same problem, wha solves it is 2 press the eject button and give the faceplates a lil pop wit ya hand, thats wha i tol everyone that has had a prob like we have and it works, try it and see.
yeah i think thats what i did by aaccident..when i pull the mounting kit out it caused a bump..and thats how it actually ejected..
are pioneers known to do this?
yeah all my pioneer decks messes up somehow..but they're good decks...
next time ill get an alpine...but i love the service plan at bestbuy..helped me out a lot
turnstylez18
turnstylez18
Toronto
SmokeyNChris
