theabbalah
I have a pioneer dehp3300, I am trying to figure out the Q settings... can anyone help explain the basics for me?
This is straight from the manual, basically I'm trying to understand how to set it correctly.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Equalizer Curve Fine Adjustment
You can adjust the center frequency and the Q factor (curve characteristics) of each currently
selected curve band (EQ-LOW/EQ-MID/EQ-HIGH).
1. Press the AUDIO button for 2 seconds to select Equalizer Curve Fine
Adjustment.
Note:
• If you make adjustments when a curve other than “CUSTOM 2” is selected, “CUSTOM 1” curve is
updated.
4. Select the desired Q factor with
the 5/° buttons.
2N +=1N +=1W +=2W
3. Select the desired frequency with
the 2/3 buttons.
LOW: 40 ï80 ï100 ï160 (Hz)
MID: 200 ï500 ï1K ï2K (Hz)
HIGH: 3K ï8K ï10K ï12K (Hz)
2. Press the AUDIO button to select
the desired band for adjustment.
yeh I know I need a new HU
Adjustment.
Note:
updated.
the 5/° buttons.
2N +=1N +=1W +=2W
the 2/3 buttons.
