pioneer head unit help
wolf55
hey i know every1 complains about pioneer head units...
im still getting a bit of engine noise even after grounding the head unit properly..
i only get the noise when the engine is runnin...
i grounded the chasis to the rca and it helped alot but i still get sum noise..
i hate the noise!!!... its only there when the engine is on... can sum1 make any other suggestions??
Here is a pioneer HU ground fix tutorial:
http://www.icixsound.com/vb/showthread.php?t=40067
It's a quick fix and won't hurt anything to try.
I do feel bad for you though - whine is a total *****. Especially after you think you've tried everything to fix it, but it's still there.
I also believe you can create problems by connecting/disconnecting RCAs when the HU is on - so avoid that. Also, tweaking gain/HU levels can sometimes minimize the whine at certain listening volumes.
i got the deh-3900.....
even if the sound is only when the engine is on... do i follow that forum??.... ive already grounded the chasis to one of the rca's.... that reduced major noise.... i only have a slight noise when the engine is on...
With the car running pull the rca's from the amps and see if you still have noise. If so then it's coming from your amps. If not then it's between the HU and amps. Probably from the RCA's either they are crappy and broken internally or they are ran near power. Could be a HU ground issue as well. Check the rca's for kinks, coils, pinches and screws through them.
wolf55
wolf55
miami, fl
hoss
vegang
vegang
