pioneer deh-p90h
SQ is the SQUAD
i have a couple of questions on this unit
i know it is fairly new, i want to get this unbti to run sound, but i am also going to get a pioneer 7 inch wide screen indash (prob 7300dvd).
my first question is, with alot of bass, is this unit likely to skip or not work or does it have good skip pertection.
roughly howmany mp3's can i squeeze into 10 gb
does
is it worth buying this raido just for the auido or will the auido provided from the 7300dvd be just as good.
i mainly wanted thise for the 10gb harddrive. i have a double din in my impala so i can squeeze both inthere together
here are the specs on the raido:
MOSFET 50W x 4
XM Satellite Radio Ready
Controls optional GEX-P900XM or GEX-FM903XM Satellite Radio tuners (as External unit)
8-character display for XM Radio text (no scroll)
Steering Wheel Remote
Soft Key Operation
Rotary Volume Control (Pop-Up)
10GB HDD (Hard Disc Drive) Built-in
ATRAC3 Compression with 132kbps/105kbps recording modes can store up to 200 CD's of music
Record digitally from built-in CD player (real-time ripping speed)
SCMS (Serial Copy Management System) compliant - cannot record from serial copy
Record other sources in analog mode (cannot record from AM/FM tuner)
Gracenote CDDB™ Database Built-In
Automatically adds track tag data (Artist Name, Song Title, Album Title) to music recorded from the built-in CD player (digital recording)
Quarterly database updates available
Automatically generated Playlists
Digital/Analog/Artist/REC Date
Custom Playlists
Up to 6 User-created Custom Playlists
MagicGate™ Memory Stick® Player (Playback Only)
Built-in DSP
13-Band Graphic Equalizer
Frequencies: 50, 80, 125, 200, 315, 500, 800, 1.2k, 2k, 3.15k, 5k, 8k, 12.5k
Level: +/- 12dB
5 Factory and 2 User EEQ Presets: Super Bass, Powerful, Natural, Vocal, Flat, Custom1, Custom2
Source Custom EQ memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
Auto-EQ (3 Curves, Microphone Included)
Digital Sound Field Control (4 Presets)
Octaver Bass Enhancement (2 Modes)
BBE (+/- 4 Step)
Time Alignment (2 Modes)
Digital Automatic Sound Levelizer (ASL) with Built-in Microphone (5-Mode)
Two-Way Crossover Network (Normal Mode)
Front HPF: 50/80/125Hz, Slope -12dB/oct
Rear HPF: 50/80/125Hz, Slope -12dB/oct
Subwoofer LPF (Mono): 50/80/125Hz, Level -24 to +6dB, Slope -18dB, Phase (Normal/Reverse)
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
RCA Preouts (x3 pair, Front / Rear & Sub) (2V)
Advanced Organic EL Display (256x80 pixel)
Full-motion 3D graphic animations including
4 screensavers (CART Racing, Echoes, Sonic Line, Omegaroid)
4 Spectrum Analyzer displays
5 background full-motion animations
12 background pictures
Off (text-only) mode
2 Display Modes (alternate screen layouts)
Form 1 includes 32-character text display capability
Form 2 includes 2 lines of 24-character text display capability
Adjustable brightness level (32-mode)
Customizable Display Download Capability (PC Link Kit required)
Visit http://www.pioneer.co.jp/car/pclink/index-e.html for more info
Cellular Mute Capability (CD-CM1 required)
Clock
Compact Disc
Track Scan/Pause/Repeat/Random Play
Audible Fast-Forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text
AGC (Automatic Gain Control)
MP3 CD-ROM Playback
8x oversampling
3-beam laser pick-up
1-bit D/A Converter
Anti-shock mechanism
Chassis
DIN Mountable
Detachable Face (faceplate carrying case included)
Flap Face
Radio
Supertuner III
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
SQ is the SQUAD
SQ is the SQUAD
Boston, Ma
SQ is the SQUAD
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
