Pioneer Deck popping
factory amp turn off pop
Now that you mention it, its only the rear speakers and i think i read somewhere that the rear is amplified seperately... now if i can just figure out where that is
What about Sony decks? I have popping noise when I turn volume up or down and switch sources and powering on and off. I have a two amp set up right now. What do i gatta to do stop the popping noise.
grounds and grounds. on last years comp setup i had full grounds all going back to the same place and even then pioneer didnt like it. the only thing i didnt try was isolating my signal cable. i ended up with alpine, and havent had a single problem with its grounds.
I still have a problem with popping sound. coming from my speakers. If I tune volume down completely it pops and the end, If I change source it pops on ech change, If I power on and off it pops. Please help me figure this. I just redid the two stage amps and made sure grounds where good. The only thing I can think of is the deck or RCA's need to be better shielded. Let me know what you think
I re did the stage amps and still pops when I change sources, or turn on, or tune volume al the way down.
I am thinking this either a deck proplem or rca's need better shielding. plz tell me what you think.
sandbags
sandbags
NY
subzero
