Pioneer AVIC-D1 navigation not working
timmyjimmy5150
I had a sound store install my Pioneer AVIC-D1 in my Ford F-150.
The radio works but I can't use the navigation options. Even when I am parked with the parking break set --- I can't input addresses; set options; or even set the clock.....
What could be the problem? The map displays and shows where I am currently going.... But all other options are locked out all the time.
Is there a bypass for this D1?
thanks
tim
It's mystically not bypassed. i have a d1 too. there are bypassing directions some where.
I know this sounds dickish. but i'm not trying to be. go to google.com and search avic-d1 bypass, and many car sites will pop up with directions, and people saying it work. and i can tell you, it does.
If you want to bypass it yourself it's quite simple.
On the D1 harness, find a wire that you are not using. Pull it out of the harness (with the pin connection still in tact). Now, look on the harness, you'll see an empty slot on the connection next to the black ground wire. Stick that wire you just pulled out into that pin, and splice that wire into the ground.
That will fully bypass the D1.
timmyjimmy5150
timmyjimmy5150
harvard
Randy Savage
