Pioneer AppRadio 3 issues
  • 5
mjboss
Hi. I had this HU installed at Best Buy (I know, problem #1 ), and I think they did it wrong. I understand the parking brake must be engaged to enter addresses or use the video screen, but when I enter into a GPS app on the unit, and remove the parking brake, the screen goes black. This CAN't be what Pioneer intended, what good is GPS Mapping if it only works when the car is stopped and the parking brake on? Anyone?
no there is a voice from the unit that tells you were to turn and go .just the screen turns off , so that you keep your eyes on the road .usually a simple toggle switch between the ground and parking brake wire works fine .
Most if not all aftermarket GPS in dash units as well as factory units do not allow you to type in an address while the vehicle is in motion. My Lexus has factory nav and it does not allow me to enter an address while driving.
Thanks for all the reply's guys, I called Crutchfield and it's actually the App I was using, it says "Compatible with iPhone 5" but THAT version is not compatible with App Radio 3, go figure. I downloaded an alternate (not as good but...) Nav App and it works fine. Thanks again for the responses.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
461
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
885
mjboss
mjboss
Cincinnati, OH
mjboss
    Jun 1, 2024
    May 31, 2024
