pioneer 860MP sub output control
What should I have the different frequencies set at? Im asking about the frequencies available for subs only. Should I leave all of these at 0? Also, I thought there was a sub level control, but Im not seeing it.
frequency should be at about 80 hz. slope imo was good at 12db's. i usually left the level at 0.
i have mine at 63hz with a -18 slope although i find
myself cheating most of the time and switching it up
to 80hz...
my level goes anywhere from -6 to 0 depending on
what kind of music... obviously BME click or Late Nite Tip
need thier bass set more conservativly than a Nirvana record.
Where do you get to the level control?
While you are on the screen where you adjust the LP freq, use the up and down on the multi-function knob (right knob). You should be able to adjust the level up or down.
I am using 80Hz with an 18db slope for my S8L7.
I have my about 0 depending on if i want more thump, but i only have one 12. most of it depends on where your gain is set on the amp. so how was the change from the eclipse? i went from a 8454 to the 860.
i changed from the 3402...not really a fair comparison;)
the pioneer blows it away in every way;)
it really does have everything to do with where the gains are
set on the amp...
i set mine up with a 50hz test tone at -12 where it would not
clip... with actual music i can turn it up close to 0 with no
clipping... im planning to set it around -14 or so, so i would
never turn it up passed 0...
i drive around with a muliltmeter hooked to my amp daily so
im always watching my voltages... the sub level control seems
to increase the voltage slowly at first and then more aggressivly...
as if a particular song is only at 6 volts or so and turn the sub
level up 1 knotch it will increase by like a volt or so... but if youre
already pushing 25 volts through it... 1 more knotch on the
sub level control will bump it up by 3 or so volts...
so be careful once it starts getting loud... that sub level thing can
get you trouble quick if you play with it too much...
standard mode goes to +6... i dont know about network mode...
i love the 860 also.
zachzchw
zachzchw
ohio
g30ffr3y
